Any tips for polishing/restoring a cloudy back window?
samuel_m
Buckinghamshire, UK
last owner said just put wd-40 on it… which admittedly works for a while!
I was wondering about gently using an oscillating sander with varying grits, much like restoring headlights.
Trevor /chedder
Ive tried plastic X and it didn't seem to do much. Anyone tried that sanding idea?, I had the same thought 🤔
TJS
Z1
Not sure I would want to use an orbital sander / polisher on a flexible plastic rear window. The heat build up could distort the plastic unlike the hard polycarbonate of headlight units.
I use Renovo polish. You need several coats, inside and out, alternatively test toothpaste on a small area, it improved a small area affected by bird lime.
shera25
WD-40 only masks it, so you’re right to look for a better fix. I’d avoid an oscillating sander, as they can heat the plastic and make things worse. A proper plastic polish kit (same type used for soft-top rear windows or headlights) with hand polishing is usually the safest way. Slow and gentle gives the best results.
NeRo
Linlithgow
I always used to use Autoglym Super Resin polish - mainly because it was left over from doing the paintwork
Seemed to do a decent job!
I'm going to try that. If it buggers up my window I shall blame you!:thumbsup:
GZed
Shrewsbury, Shropshire
Z3 2.8 Prefacelift
I used Renovo with some success on my red Zed. As T-Tony (RIP) said, it helps if you have someone inside the car holding a rolled up towel or similar against the window to give you something to press against. I didn’t have anyone to do this, but still gained a visible improvement
samuel_m
Buckinghamshire, UK
Thanks all. I will not use the sander then. I'll give one of those plastic restoration products a go and post the results. :cool:
Berk
Mequiars Plastic cleaner. Small white black bottle. Microfiber cloth rub it in and the magic begins. Looks like soft scrub liquid cleaner.
