After 2 hours draining and disassembling the engine to get to the oil filter housing the top left bolt broke.
And it broke in the most inconvenient spot. I cannot weld on top of it because the hole is too small and I need a long and thin drill bit to extract it.
Every mechanic in Stoke-on-Trent is busy until next week and I am lost.
Can is dry sitting on ramps and the plan is to get some long thin drill bits tomorrow and try make a clear hole before using the extractor.
But I have to use the extractor at an angle anyways... And it doesn't seem to work.
For now it's sitting with a lot of WD40 in there.
If I could I would break the bolt in two so I can have access and then extract one half from the housing and the other from the engine.
I don't want to put a screwdriver between the engine and the housing to try and brake them apart with the screw in case I damage the surface and end up with leaks.
I am lost. Thanks for any help.
