Bonnet release lever
Z3newbie!
Probarbly going to be lots of questions now we have an MOT!
Bonnet release lever feels like it does nothing and bonnet will not push down and lock, it does stay shut up to the manual release lever under the front of the bonnet but not all the way down to work from the lever in the car.
Any ideas?
It if won't push down and lock it should have failed the MOT.
You should!
Personally I wouldn't like driving it unless it's locked down. Look at the catches under the bonnet see if you can move them. Might just need a bit of movement and lube. Or maybe the cable is rusted solid.
mwpe
Camberley
If the bonnet is not latching down properly it is worth replacing the latch mechanism and cables, they tend to sieze up with age. They are simple and cheap to replace and if they end up siezed in the closed position, it is very difficult to get the bonnet to release.
ExMX5owner
Moderator
Australian Zeds
Queensland, Australia
Any ideas?
Mine did the exact opposite would not open, in fact I nearly broke the handle off trying to get it to open, a little bit of CRC on the catch to free it up and its been good as gold since..
Z3newbie!
Is it a difficult job?
I have a couple of slam plate catches and the small bowden cable that joins them.
Let me know if you need them….
Z3newbie!
So I cleaned the springs and rods on the bonnet and the catches.
I was able to encourage out the catch on the bonnet bit to let me shut it securely and then opened it again with a little jiggling.
The catches did not pop out again so had to coax them back out again and repeat.
how do I actually fix this longer term, happy it is locked shut now though.
25 year old cable will have had it..I’d replace the lot for piece of mind ..he says having had the parts for his in the boot for the best part of a year 😕
