Bought a Z3 - it failed MOT - advice needed!
Z3newbie!
If you're going to undo those torx bolts to remove that plate then you ought to look at this bush at the same time.
It looks shot (To me anyway)
Doing it properly is quite a big job involves dropping the whole cross member to insert new bushes. But if you search on the forum you'll see a few of us have replaced those bushes with the cross member in situ. Bit fiddly but DIY doable.
I will try to find a link and see what it involves, not sure whether to just get it through its MOT and worry about other things later or plod on with a few bits along the way. This is a learning experience for me as never had one before and quite a novice to be fair.
Z3newbie!
The Z3 is now in the garage for welding, plan is to remove bolts and bracket, weld up inner sill, replace bracket, knock off other loose rust, treat the underside, seal it and then MOT time.
Fingers crossed!
