Coilsnot Working but good
Chamber66
Swansea
I have 3 ignition coils on my 2.8 not working, but when I connect them to a other cyli der the work. As in co nect number 2 to number 5 wiring it gives a spark. What can cause this?
bertiejaffa
Manchester
Z3M
If the coils work when switched then I would definitely think ECU issue - I had it on my M where a full bank was down - theres very few places got the kit or knowledge to fix them these days.
On the plus side - there should be plenty of Breakers for 2.8 ECUs, not something you have the luxury of with the UK M.
However, try giving these guys a ring https://www.avilec.co.uk/ There is an old boy there who was able to fix - I actually sent it to a guy in Yokshire first of all who has connections with these guys at Avilec - seems like everyone uses them for this type of thing.
bertiejaffa
Manchester
Z3M
What fault codes are stored in the ECU?
In my situation the problem with the ECU was a chip that had gone faulty and a replacement new one needed to be ordered from Germany and replaced. Because of this, there were no fault codes on my ECU as the ECU obviously didn't know that it itself had gone faulty.
bertiejaffa
Manchester
Z3M
@Chamber66 - I should have also mentioned that if you did get a replacement ECU module from a breaker then it might have to be coded to your car
ChrisD
Evesham
M44
If the OP has the same symptoms then repairing the ECU is the correct course of action. I'm not seeing that other diagnoses have been ruled out currently.
Chamber66
Swansea
I am going to do another diagnostic on it this evening. I had a guy come in last week and it wasn't showing any codes?
My thoughts are it can only really be a ECU issue or crankshaft, cam sensor??
ChrisD
Evesham
M44
Thorough check of wiring/connections back to ECU would be prudent.
bertiejaffa
Manchester
Z3M
Both sensors would appear on a diagnostics tools I would assume?? I would contact Avilec and just run the symptoms by them, they will be able to tell you if they have seen it before I would suspect.
