First BMW, and it's been on the road (slightly) longer than I have.
How's it going? I recently moved from Honolulu to the middle of the desert outside of Barstow, and I've been on two wheels exclusively for the last three years. Actually just traded my Honda CB500X for a brand new Transalp (and it absolutely rips). A couple weeks ago, I bought my father-in-law's 1998 Z3 1.9 that he bought new while stationed in Germany and had it shipped from Massachusetts out to California. He was very reluctant to let it go, but his clutch knee just couldn't take it anymore and selling it to me at least kept his favorite vehicle in the family. He upgraded the suspension and other parts, mostly with AC Schnitzer parts I believe, and had it tuned by Dinan. This is definitely not like pretty much any other vehicle I've owned, save for the third pedal, and I'm already finding "BMW things" that I need to wrap my head around.
The first headache was just getting the electric soft-top back up. I'm not proud to admit that I spent a solid 10 minutes trying to reason my way through it before I had to go find the manual. Turns out you have to lower both windows AND hold the brake... Also, it regularly pops a check-engine light but I wasn't able to get much information about what the actual code is (yet). It has an OBDII port under the dash, but it looks like it also has a different, round, OBD port under the hood on the passenger side of the engine. What's that about? What's the difference between the two? What would be a good code reader that is known to work well with this little roadster?
Also, I'm already finding things that I want to tweak and parts that could use a replacement. Where could I find a good wiring diagram for the car, and are there any reputable OEM quality parts suppliers for interior and exterior trim pieces and the like?
Finally, are there common failure points I should keep an eye out for? I think I saw something about some sort of solenoids in the intake that are a common issue, and something about the rear subframe or something that can crack over time.
Any enlightenment you guys can send my way would be appreciated.
Thank you,
Chase
ChrisD
Evesham
M44
Thank you,
Chase
For a good, cheap OBDII scanner, take a look here:
You’re lucky on a number of fronts. Firstly, to connect to the engine controller, you don’t need to worry about the round 20pin diagnostic socket in the engine bay. That’s a BMW diagnostic socket and unless you have the right tools, training and reference material it’s not going to be very useful. Just go straight into your OBDII socket - older cars in the UK don’t have this hence the use of an adapter for the 20pin BMW connector.
Also, with your engine, you don’t need to worry about intake solenoids (VANOS) or, unless the vehicle has had a very hard life, the rear subframe cracking (trunk spot welds).
Enjoy your new car and welcome to this forum.
Delk
Hemsby Norfolk
Z3 3.0T
Picture?
You need an adaptor and use the round plug near the engine. Dont ask me why but thats the way they made it. Adaptors are common and not very expensive.
Massachusetts and Hawaii will not be good for rust so keep an eye on the inner sills and jacking points. Removing the outer sills at some point and rust proofing the inners would be my recommendation.
