Odometer brightness
Althulas
Banburyshire
M Roadster
Z3newbie!
The headlight pull does not adjust the brightness of this so I presume I am going to need to remove the instrument cluster and change the bulb, whcih bulb does it need behind the mileage?
The dimmer switch works on the Speedometer and "clocks" in general but not the Odometer specifically as such. New bulb(s) needed.
