Andrew Lockwood
- Jul 28, 2019
I have a 2001 1.9 Z3 (facelift version).
According to my error code scanner, I have three errors under the heading ABS / ACS / DSC:-
The practical problem I have is that the car won't idle - it stalls when I take my foot off the accelerator. The various hoses all look fine, so I am guessing I may have a problem with the idle control valve.
However, my scanner has an option to adjust the idle speed, but it won't let me use it until I clear all the error codes. I thought it might be worth trying that before starting to dismantle things.
Can anyone help me work out which relay is causing the first error and to interpret what they all mean? Presumably the first thing I need to do is to swap it and see if that makes the error(s) disappear.
Any help will be greatly appreciated!
- 82 Main Relay Voltage Error
- 93 CAN data error from DME/DDE
- 94 CAN data error from DME/DDE
