Repairing broken undertray fixing stud
IvorZ3
Suffolk
Z3 2.2i
I have a really good condition z3, but one stud used for fixing the front wheel arch liner to the rear has rusted and sheared off.
Is there any way of buying and attaching a new stud, I think if i drill it, it will go through the car floor into the cab.
Thanks for any help.
IvorZ3
Suffolk
Z3 2.2i
Thanks very much for the replies, both very helpful......much appreciated.
IvorZ3
Suffolk
Z3 2.2i
I did the same as Pingu except I loctited some stainless steel threaded bar instead of using a bolt which in hindsight would be easier.
I'm looking at your rebuild thread....amazing amount of work you did and very useful to read....I see your studs went in exactly the same place as mine, the one towards the outer edge/sill....I expect this is more exposed in some way....my inner one was perfect, the outer rusted. If i drill this area does it go straight through into the main cab or is there some kind of box section / void behind? Thanks
IvorZ3
Suffolk
Z3 2.2i
You can order these pop rivets from Volkswagen, part number N90716103. Be careful when drilling a hole, there are several wires attached to the chassis floor from the inside.
Do you know if i would need a special tool for these or does a standard pop rivet gun work? Thanks
If you are talking about riv-nuts, the tool is a converted and stronger pop-rivet gun.
When you buy one, you need to consider the access you will have, and the maximum riv-nut size.
I have one that looks like a normal pop-rivetter. I need access at 90° to the job to uses the tool, and the biggest riv-nut that I can fit is M6. You need to be able to crush the riv-nut, and my tool crushes the nut by squeezing my grip.
In hindsight, the one that looks like a pair of shears would be better, but couldn't be used in a confined space.
Horses for courses :) .
DomiMik
German Zeds
🇭🇷 》Croatian living in Germany《 🇩🇪
Not cheap!!!
Ebay scam, that's why I wrote that these rivets should be ordered directly from VW. Should cost less than half of the eBay price.
