#ZedShed Saul’s Aero Princess - 2.8TU & 6Speed package
5 years ago we did Saul’s overhaul when I was still doing them at home. Now she’s back for all the bells and whistles, the 2.2 lump is being removed and she’s being replaced with the 2.8TU very much like my old Z3 build that made a healthy 245bhp.
Aero goodness
in to make a start this weekend
engine and gearbox
watch this space. Lots of custom work
Will be following this especially around the 6 speed can you list if possible parts used as well as your usual procedure side .
We’re loose with some details for obvious reasons. Some of these parts are a fair price and don’t want a rush with people buying them up :)
Scooblitz
Glasgow, Scotland
Most excellent.
Pulling up a chair.
Are there plans to change the diff now there will be an extra gear?
Most excellent.
Pulling up a chair.
Keeping the 2.2 diff with it's 3.38 ratio gives the zed feeling like M acceleration, if we kept the 5 speed box the top end is reduced to 135mph which used to bug the hell out of me when I ran this setup in my old zed. So bringing the 6 speed along with the same 1-5 ratios the 6th gets you back the good mpg on the runs. We saw 40mpg with Dino's 6 speed conversion.
Engine is out of the car already, not had an hour to myself to update the thread :p
Scooblitz
Glasgow, Scotland
6th gear would be lovely for the MPG on the motorway. Interesting the combination with the original diff is a good blend.
  • Agree
It's a pretty straight forward swap to be fair. Prop shaft needs shortening about 110mm and the linkage for this box also shortened. Everything else is from other BMW's.
So this Saturday we smashed the fist stage. The old 2.2 is now removed. (If anyone needs it let us know) only real hicup was fighting the steering rack going through between the cats, so we in-bolted the rack.
First jobs included removing the exhaust and drop shaft. Also disconnected the gearbox linkages and wiring loom.
Move up front we needed to get the fluid out the rack and radiator.
also started disconnecting the loom for the lighting and various sensors.
We had planned this job well in advance so Saul had the aircon degassed which made our lives so much easier. We noticed the front slam panel loose and noticed it had been replaced at some point. The old drilled out spot weld are a give away.
Once the front was exposed we needed to get the engine loom off the car and also the inlet mani, behind it is the rear lifting point.
inlets looking clean, 117k engine
hooked up the engine crane. Because we were removing the engine and gearbox we used our tilt bar.
As I said the rack linkage caused us some issues but quickly sorted once unbolted.
she’s huge!
car now ready for Saul to work his magic painting and cleaning things.
in total this took around 5 hours. Roll on the next big update :)
Some really juicy pictures for you all.
all the hardware for the front is with the powder coaters.
Saul got cracking on stripping down old paint n corrosion.
and today I started to assemble the engine with all the painted bits.
was a good exercise today to see what were missing. Need another water pipe so proved very useful to do.
Some of the ancillaries going back on.
Exhaust manifolds look smart but are the wrong ones so these have come off.
next up rocker came off along with Vanos for a rebuild. Saul wanted to paint it first so I’ll do it next week.
looking really good for 40k miles from Japan.
oh new toy arrived today, should make bush n bearing removal a lot easier.
next order of parts done. Roll on next week.
One big step closer this weekend. Hoping to get the engine and box together and placed in the car for next weekend. Got more of the engine together today.
Vanos had a rebuild.
always tough getting these undone
Old seals and rattle rings
ready to rock now
in place ready to be bolted. Also got the main aux belt fitted. Good sanity check, painted rocker cover also went on. also if you look closely a real smart braided high pressure Vanos oil line.
next I tackled the new exhaust manifolds. Took ages removing the old studs. Worth noting these manifolds finish in the same place as the OE manifolds.
tips together
just waiting on the aircon pump to return
while I built this Saul painted the engine bay
waiting on the subframe to return from the coaters. Also got a new steering rack. No expense speed with this build.
I did test fit the 3.0 Manifold but we removed it for cleaning and painting
Next update next weekend :)
PHILIP BAXTER
Cardiff
Z3 3.0i Roadster
Another great thread Lee. I will have to book in for the new year to sort that oil leak and engine mounts
