Hi
So my 1.9 Z3 is currently on what i suspect to be 30mm Lowering springs.
The front are corroded as mentioned on previous MOT and i have now broken a rear spring. So ive been weighing up my options as i plan on doing the following work anyway. (Replace front lower arms, discs, pads)
So the question i have is do i
- Just buy a set of 4 new lowering springs
- Replace Coil-overs as well as springs
Im not looking to spend hundreds. I Have seen these TA TECHNIX Coil-over set on Ebay which im swaying more towards atm as they're reasonably priced and adjustable height. TA Technix Coilovers Set BMW Z3 E36 Lowering Suspension | eBay
Has anyone fitted these to there Z3? Any Good?
Ideally id like to buy some better quality ones but dont want to break the bank.
if anyone has any recommendations or ideas on what i should do that would be greatly appreciated.
My budget For a set of Coil-overs and springs is around £500 maybe £600.
Many Thanks
Tyler
Many Thanks
Tyler
