This clunking is driving me crazy, help!!
Rango
On my 2000 z3 2.8 5 speed I have a deep metallic clunk (sometimes multiple) when I shift from 1-3 and it seems like it’s coming from my trans or the back of the car I know it’s getting up there in age being 25 years old with 108k miles but I don’t know whether to assume it’s the diff bushing or the guibo as I don’t have a lift to properly see under the car, thanks!
shera25
On these cars it’s pretty common for that kind of clunk to be driveline-related rather than the gearbox itself. Worn guibo, center support bearing, or diff bushings are usually the first things to check, especially at that age and mileage. If you can’t get it on a lift yet, keep an ear out for whether it’s worse on on/off throttle, which can help narrow it down. Hopefully someone else can chime in with what fixed theirs.
Other than the obvious bushes etc, lift the boot carpet and check the diff hanger spot welds haven't let go. Another odd one, check the rear anti roll bar brackets, they are only spot welded on, if one lets go you will get a clunking. (happened to me)
Grumps
Always happy, apart from when I'm not 🤬
Forest Town, Mansfield
Z4 e85 2.5i
Diff slap. My 2.8 used to do it. If you drive smoothly through the gears you will likely find it won't do it.
Z Victor 1
Formerly "Ontiken1"
Ripley,Derbyshire.
E 89 Z4 S drive 23i
Yup, my 2.8 had it at 30k miles!! To be honest every BMW I've had , especially the 1990 s to 2009 models had poor gear changes from first to second in particular. Changes from third upwards are ok.
