What DIY scanner are you using.?
Acousticplayer
Leicester England
Hi everybody. I've been chasing down a misfire for almost a year now. Several times I think the problem has been solved only for it to return not always on the same cylinder. Started on all the bank one cylinders together. Then ,moved to cylinders 2 and 3 only and now it's cylinder 1 only.. The whole scenario is beginning to look ridiculous. I've been using an old AUTEL SCANNER but it does not show real time data. Does anyone use a more sophisticated scanner that can get me straight to the problem.? Thanks
