Abs will work fine lights off etc its the traction control that needs coded light will go out on dash and go on and off with switch but wont actually work.
Whats wrong with the original as bar the solder joint that goes inside ( documented fix ) they are usually pretty reliable.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
