Rebody 250 California build thread for dummies
Last piece made and fitted; a bespoke quad exhaust in stainless. Sounds nice but not noisy.
I had confirmation from the insurers on the agreed value today, following me sending them pictures and info last week.
In the agreement letter, they asked if I wanted to increase the value, which I thought was bizarre.
mikeyH
South Devon
2.2 Z4 E85
Good news, it's obviously worth more than you think it is :) :thumbsup:
Only problem is it comes at a cost. If I increased the agreed value, the premium goes up. Nothing is free in life!
and the heater control wires are akin to wrestling with a very angry snake. Doing all this in 32c heat doesn't exactly help either!
OK. And having wrestled with the angry snake - what did you do with it? I don't see your heater controls in any of your pictures?
Heater controls are below the centre gauge pod. Three 'choke knobs' on braided wire. All are push/pull. One for heat, one to adjust the internal flap for windscreen or footwell vents. The third is a dud in my case, as the amount of aggro to connect it to the other flap wasn't worth the negligible benefit.
The BMW heater has a little microswitch which opens and shuts a solenoid for water to flow around the matrix. I couldn't find a way of re-using this, so mine has water flowing around the matrix at all times.
The vent controls are the three central ones. Far left is an aux socket, far right is the hazards and the other is the fan speed switch. I don't have an A/C switch as I didn't want it.
On a standard (ie non messed with zed) how is that water flow valve controlled? I expected it to be a pull/push cable that could partially open close the valve - but you called it a solonoid. So is it just fully open or fully closed? Is there a thermostat that opens/closes it based on the position of the blue-red knob.
So in your case it's always fully open and you avoid cooking in summer by simply closing the flaps?
There isn't a water flow valve, only air flow ducts. The water flows constantly through the heater matrix, but air only flows over the matrix and along the ducting when the appropriate setting is chosen.
ChrisD
Vale of Evesham
M44
The heater control valve allows coolant to flow into the heater matrix. It looks like this:
It is mounted in the rear of the engine compartment. It’s somewhat buried but it can be seen.
The heater control valve is controlled via an electrical switch on the temperature control dial, as shown in the schematic below:
Sorry I don’t have a better picture:
Yep and turning the fan off!
Yes, there is a microswitch which is made/broken by a small moulded part on the BMW heater control wheel.
Too complicated to use it when changing the heater controls TBH, so I binned mine, which means the valve/solenoid is always open!
Yes there is. :thumbsup:
I thought it was used for bleeding. You're right, though. The valve is opened when the temperature is switched away from cold (wiring diagram says "switched to maximum", but the microswitch is near the cold setting).
It opens flow into the heater matrix.
Another school day for Pingu :thumbsup:
I have been 'fettling' my car over the past month or so, as I can't drive it.
I have cleaned, re-coloured and re-sealed the roof. That Renovo dye is crap. I'm sure it's just watered down black emulsion! I really don't like the look of the car with the (Z3) roof up but it makes the cover fit better!
I have also fitted some cheap floor mats which look OK and will protect the carpet. Much cheaper than re-carpeting the car.
I have also given the paint it's first polish.
Today I changed the engine cover 'badges' as wasn't happy with them.
Previous attempt:
New attempt:
Synclare
Staffordshire
Well for a million quid his paint job isn't a patch on yours. Just look at those dis-jointed reflections in the front wing and door (never mind the ripples), not to mention the upper part where the reflected lines rise up to an apex instead of remaining horizontal.
That is a replica, but a very expensive one, built by DK Engineering from Ferrari parts. It has the Colombo V12 engine and the body is aluminium, not plastic!
Cost is around £1,000,000 so cheap in 250 California terms.
As Henry Royce was stated "The quality remains long after the price is forgotten", so don't be too hard on your painters.
My painters were excellent.......at painting.
Just took the shine off (no pun intended) a bit when I had to spend time and money replacing bits they either broke, lost or just didn't put back.
But as per Mr Royce, I have forgotten those things now and am left with a very well painted car. It is very very good TBH.
