This is the type of colour I had in mind
I think the same about the orange .Renault do the best candy red IMO, I just don't think it would suite a Z3 as its a bit too modern for the retro curves
Like that on the Vet but have you got an example that is not Photo Shopped?This is the type of colour I had in mind
Oh yes I like that SeanThis is the type of colour I had in mind
Here you go palLike that on the Vet but have you got an example that is not Photo Shopped?
Nice colour, the wheels thoughHere you go pal
Great colour!Here you go pal
I am planning on dropping it in one but building it in 3, I could do with a general thread as what needs removing such as prop shaft and the likesTrolley Jack under the Diff. Sean and gently release it down to the floor.
Might be wise to have a hand available when putting it back unless you put it back in pieces which, from what I've read, is the easiest way.
ps. Good progress mate![]()
Cheers pal, when you say air punch do you mean windy chiselI see. @Steve Medlock did a good write up Sean, he did his like you are on stands I'm sure. You'll need to disconnect both h/brake cables at the lever, prop. shaft at the Diff. flange. Brake pipes, top shocker mounts. When you get it down I'd bet on needing an air punch to get the driveshafts out of the hubs.
When your close to doing it drop me a PM I’ll give you a little step by step with tool sizes and some tipsOh forgot to ask, can someone point me towards a how to for the rear end drop, @Lee
Yes mate. All the BMW I've ever done the splines appear to be stuck in with some compound.Cheers pal, when you say air punch do you mean windy chisel
