Manifold
Rear disk is because you don’t use it for half of the year 😀
rmoconnor41
M7 11mm did seem an odd size to me at the time
Bmw's and their quirks
Luckily I have had good experiences so far of parts coming from Germany, being delivered in about 6-9 days
Is that £25 a nut!! Surely not!!
Good luck! Chris.
This shows the angle of the two bolts. @AntStark and I had no luck attaching the M7 nuts as the fuel rail and electric rail are in the way. Going underneath is at the wrong angle. Are there any videos or instructions for removing the rails? Thanks Richard
f
rmoconnor41
@AntStark and I had no luck with the new M7 nuts for the manifold. Unless both bolts are damged the nuts don't take.
It looks like the two bolts are angled as shown in the top photo.
Looking for some write ups and or videos for fuel rail and electric conduit removal.
Richard
We’ll try it with a flexy socket extension first before taking anything apart 😀
Undo the two 10mm bolts holding the fuel rail in place, you can tilt it over for better access. Or even lift it up slightly, just holding down the injectors on 0-rings.
rmoconnor41
Thank you
is that after prying off the long plastic electric bar that is clipped alongside?
That's the power for the injectors and manifold sensor, Can either pop that off or leave it attached.
2.8l
I would try your best to leave the electrical bar on the fuel rail, because the clips that hold it on are an absolute nightmare, at least for me anyway
Good luck !
Chris.
  • Agree
Delk
Hemsby Norfolk
Z3 2.8 real widebody
Fuel injector plugs are not bad to get off once you get used to them.
It literally takes brute force. Start at one end and pry the rail until the plug comes loose. Seams wrong at first but the plugs do just snap on and off. They don't break and the metal clip just expanded and comes off the injector.
rmoconnor41
Good luck !
Chris.
I watched a video and thought that too. Not sure which 10mm bolts @Lee is referring to that hold the fuel rail on.
rmoconnor41
Hi prying anything on a 26 year old car scares me somewhat 😀
rmoconnor41
Decided that a local garage the best option for these bolts/nuts.
Not risking prying anything that is likely to snap
