Mike’s Z3 - Fitting Retro Aircon + Cruise etc Project
MickyG
Whilst retro fitting the Aircon system, I’ve had a guy completely replace the drivers side leather bolster and foam on the Z3M seats along with sowing in a pair of new seatbelts guides. He’s made a great job of the bolster, dyeing black leather to blue. Given they are almost 100k miles old they have come up pretty well: (though I do look at my original seats which are in superb condition with a pang of regret).
I collected them last weekend and finally found time yesterday to clean and feed them with Hide Food, before swaping them over on to my original bases.
It is surprisingly easy to remove a seat from its base - it took me 10 minutes, removing 5 bolt/screws and detaching the two cables that allow the seat back rake to adjust.
Then, whilst separated, I decided to fit new bushes/washers in the Fore/Aft electric seat mechanisms - the originals tend to disintegrate over time allowing the seats to rock back and forth while driving.
Again, quite easy, once you work out how to extract the drive mechanism: after removing the large tork screw, which allows the long worm drive mechanism to be pulled out, the seat runner must then be slid back to allow the drive mechanism to tilt down 20 degrees, making it easy to remove.
Once out the rubber bushes in the mechanism are revealed.
My bushes/spacers were in much better condition than I expected, compared to those I found in the donor car’s bases: however as I had bought new replacements I decided to fit them now while I have the seats out.
The long threaded drive has to be removed from the adjuster block as it passes through the spacers: (remember to count how many turns it takes and rebuild later with the same number for both sides of the seat runners).
The original BMW spacer/bushes appear to be made of black rubber moulded as one U-shaped piece: mine are just beginning to break up.
New white individual spacers (that appear to be nylon) are readily available: they are a very tight fit. I gently hammered mine into position, being careful to tap each side, not the weak centre: others have sanded them down until easier to slide in. On the basis that you are doing this to stop the seats moving back and forth I felt “tight” was the way to go.
The most difficult part is the refitting of these driver mechanisms into the seat frame. The long worm drive shaft is driven by a square ended flexi drive, which has to be inserted into the ends of the long screw mechanisms.
The above photo, for illustration only, shows the two parts that must be joined: in practice this union has to be made inside the seat runners making it much more difficult to line up and insert.
The view through the hole is all that you have to work with. I found it useful to offer the shaft to the flexi drive outside of the runner and rotate it to get the squares to align, then feed it through the seat runner and use a flathead screwdriver to help guide the spring wire into the shaft end.
Also note the non threaded end of the worm drive shaft has to be pushed into the black rubber bushes to be fully seated. Once this part is complete reassembly is fairly straightforward.
One little tip to remember when reattaching the seat to the base is to connect the two seat back adjusting cables first: it’s not possible once the seat has been secured to the base (you know how I know!). The the rest is easy.
I have chosen to fit my facelift Z3M seats to my pre-facelift bases to retain the standard seat operating electric connections.
The only minor task left is to marry the facelift heated seat wiring to my existing loom wiring as they have different connectors.
Does anyone have, or know where I can obtain, two male 4 round pin connectors from a pre facelift heated seat, that I can swap onto my seats to make them totally original plug and play seats?
To connect to these female sockets in my loom.
Andyboy
SHEFFIELD
I use KwikFit for AC gassing. About 60 quid, ish. If it doesn't blow cold, you pay nothing. It's a good idea to carefully remove the AC sticker from under the bonnet and glue it onto your car so they know how much to add.
I had the AC on a Merc gassed up once - it still didn't work. Turns out you had to use diagnostics to tell the hateful thing that it now had gas. Once done, it was fine.
1955Davidr
Fylde Coast
You didn’t mention how bl*ody heavy the seats are, I managed to change my up/down motor and replace the bushes but getting the seat in and out was a major challenge, I needed 3. Shredded wheat!
MickyG
Very true: I find lots of things appear heavier than they were 40 years ago………
MickyG
Are there any electrical gurus on here?
I have been advised the Facelift switch for the Hard Top fitting kit rear heated screen that I am selling is designed to operate via a relay, whereas the pre face switch is heavier duty and does not require a relay.
My concern is that I intend to fit the facelift heated seat switches I have from my donor car into my pre facelift car. Are these switches lighter duty than the original pre facelift heated seat switches, and should I be looking to install relays?
I'm not100% sure but the old pre face one is very chunky, likely able to carry the amps, and the wiring diagram shows power going through the switch direct to the screen.
But the confusing bit is that the wiring diagram for the face lift version also appears to be just going through the switch - ie without a separate relay.
But I can confirm that the face lift switch is a much smaller, light weight, thing that really doesn't look able to carry the amps necessary to power a heated screen.
I bought a face lift roof with face.lift switch for my pre face lift car. When I eventually get round to installing the switch I will be adding a relay because, as I said, the face lift switch looks a bit feeble for my liking.
If you advertise the year of car it came out of then its up to the buyer to research.
I will add though that I've had my roof around 4 winters now. Drive in all weather and I've never actually needed the heated screen anyway.
MickyG
Thanks for confirmation.
Does the same apply for the heated seat switches?
There are definitely relays under the facelift seat - but are they used for the seat adjustment motors?
(There are no relays under my pre facelift seats).
MickyG
Research seems to take as long as the tasks themselves!
The internet is a great resource, but also a massive waste of time.
I have spent a lot of time trying to confirm whether facelift heated seats are controlled via relays, or directly from the console switches?
My conclusion, after extensive trawling is, despite the later switches looking and feeling less substantial, is that they pass power straight to the heated seats the same as the pre facelift versions.
So that is how I intend to operate my new heated seats. However, I need to locate the heated seat pads 4 pin socket to mate with the one included in the original car loom. Apparently these are made under licence by Molex for BMW so are not sold commercially to end users.
But the “couldn’t care less about patents” Chinese have copied them and put them out to meet the need.
As part of my “Mission creep” I’ve decided to swap the facelift centre console with its round analogue clock into my pre facelift car. This is not a direct swap, as my car was supplied with the square On Board Computer. (OBC).
I’ve located the original wiring loom hidden under the carpet that would power the digital clock only, and spliced the analogue clocks plug to power it.
This has left me with what to do with my original square OBC? To give me options I’ve cut the maximum length of wires from my donors loom and spliced these on to my car’s existing loom: the thinking being that the additional length will allow me to relocate the OBC to either the centre console ashtray area: or if that proves difficult to see when driving, then attach under the dash . These will pink crimp/heatshrink self glue joiners are excellent for this type of job. Once crimped applying heat warms the internal glue and shrinks the plastic making a very strong and watertight join.
MickyG
How do you define “Difficult”?
Yesterday I spent an hour and a half in my shed, and achieved fitting just TWO small screws in the dash!
It started badly when I went to fit the first and realised I’d not fully seated my upper dash on the two centre mounts: this required undoing 7 fixings (3 under plugs made difficult to get at by the sloping front windscreen). Once loosened, and the dash realigned the fitting of the two centre screws took ages - all whilst lying head first in the footwell with my ankles up around the roll hoops! At 67 it’s not a dignified, or comfortable position to squeeze oneself into!!!
To quote Dave L2 whose excellent “How to” guide I’ve been following : “These are without doubt the most difficult of the whole project. ……… and boy was he right!
However, as may have become apparent, I have a terrier like instinct when faced with challenges like this and persevered until the little b******s were finally in and tight. On occasions like this I revert to the comfort of home and “The beer that I deserve !”🤗😊
Today has been last minute Christmas shopping and an enjoyable relaxed lunch in Stamford😋🤗
Happy Christmas to anyone still tuning in.
Enjoy whatever you do with your Zeds
MickyG
This is a great read, keep up the good work. I totally agree on the seat issue, my first Z3 had cloth seats and I could not get comfy in them, I had them refurbed with new foam and leather cover, then put the front spacer raising bolts in, I still have them, but still not right should anyone need some. Some time later I had a "poverty" spec 630Ci and the seats let that down. When I saw my current Z3 for sale the idea of sports seats appealed and have proved spot on and I am now completely comfy with them.
Hi David
I’ve just been reading back through my progress and picked up on your comment regarding front spacer raising bolts: is this the Southern Boy kit with a large washer and special female threaded bolt? If so I would be interested in buying it please?
Mike
It seems like you have found your own answer but just to confirm.....
The relays under the seat are only used for the motors, not the seat heating or seatbelt 'explosive'.
They are there to reduce the load through the seat switch.
Seat heating is direct, as is the feed to the seatbelt 'firework'.
This is as far as I can remember as I ain't getting my seat out again to check! ;)
1955Davidr
Fylde Coast
Sod’s Law, the plastic box with dividers that I keep nuts, bolts, washers etc decided to spill its contents all over the garage floor a few days ago, I just slung them all back to add dividers and sort into order another day. Last night I managed to find three seat raising nuts, they are just long 24mm nuts, no idea where I got them from back in 2011. Will have another look today but happy to send them to you, two are all you need for the drivers seat, pm me your address and I will send them on.
MickyG
Thank you very much David
Two would be great, as I understand they improve the driving position for taller drivers.
As part of my mission creep, I am seriously considering re-designing my donor car’s seat bases to remove the seat height adjusting mechanism which my initial observations suggest the back of the seat could be lowered 25mm (1”).
Hi David
That’s very kind, thank you. I believe they make a noticeable difference. I’ll PM you my details.
As ever my mission creep keeps creeping!
I’ve been eyeing up the seat bases from my donor car, with a view to eliminating the seat height adjustment mechanism, which I estimate will allow the back of the seat base to be lowered by around 25mmm.
It will require a lot of planning/designing as well as calling in some favours to get it re-welded, but fortunately I can carry out all the revisions off the car while I carry on with the standard bases.
