hi all,
so I'm on the hunt for a Z3 but I'm undecided which engine to go for, 2.2, 2.8 or 3.0?
got a budget of up to £7k. 2.2s are readily available for way below that and there are a number of 2.8s and a couple of 3.0s for 5 to 7k
I like the pre-facelift widebody which basically rules out the 2.2 and the 3.0
obviously I'll be going for as low a mileage as possible but I'm lead to believe that a higher mileage one that's got a FSH shouldn't be a problem.
hmmm decisions, decisions
to the Forum from West Cumbria. All top choices but if it's a pre-facelift you want you'll get a top draw 2.8 for that money. Buy from an enthusiast if you can as much, if not all, the work will have been done, or buy cheaper and get it done (bushes, cooling etc). Mileage isn't an issue, as said, these engines are bulletproof with the M52 2.8 being as robust as they come, 100k miles isn't even run in if maintained properly. I've had my 2.8 for seven years and have never had to top the oil up at any time.
