. So phoned the local Stealer and ordered them… might as well use the correct ones !!
….So bit a fine wet’n’dry and me spitting on it
, got the 4 areas nice and smooth… happy with that ….so primer, top coat and clear lacquer required….. Off to Halfords !!!
Another "niche" market there maybe Malc?Onwards and sideways….
Found a small ‘dink’ on the rear wing to got it up to the same stage as the others … might as well do all the spraying in one go.
Waiting for a warm , wind free day though.
Went delving into the unknown this morning as never worked on a six pot engine… so all new to me
Worked out how to unclip the HT plugs… so did all those, pulled up the coils…. Some seemed looser than others, but dont know how they are meant to be so they may be ok
The Plugs though, was a different story 1, 5 and 6 … about what I expected ….4 was just about finger tight, but 2 and 3 were a nightmare…. Really tight on the whole length of the thread as they were undone.
Plugs dont look that brilliant so will get 6 new ones.
This was to remind me how it goes
And blocked up the holes to stop ne dropping anything in them
Plugs are a long way down … but luckily I had a plug socket that fitted oerfectly… bought it when I had a Smart Car…. But sold when I found out it was Smarter than me
I was going to turn the engine over but a mate turned up and got sidetracked but in a good way
Two years ago when I got the heap… sorry ,I mean car!! The wing mirrors were basically f****d…. So once my mate had fixed up his new workshop in his garden shed… we looked at what could be done.
And He has come up with the answer….
A stainless steel pin with a washer and a circlip to replace that ‘usually rusty bit of seized crap’, that holds it together.
Got any pics of that ? .....where do I send the moneyA stainless steel pin with a washer and a circlip to replace that ‘usually rusty bit of seized crap’, that holds it together.
Hopefully it’s less than £100 a mirror! I may be able to salvage a spare from mine.Onwards and sideways….
The parts!!
Sandblasted spring and pin
And washer and circlip on the other
And yes you have to compress that spring!!!
But with the new ACME fitting tool ..’simples’
access to fix in the circlip
For anyone interested in a repair set ( and I can loan you the tool) then please message me and I will give you either a phone number or email address to contact Ian directly.
Not my project this time![]()
You had me wondering thenLooking good Malc, did you remember to torque the rears best find a pipe extension![]()
…but I did them when I rebuilt the back end and did all the torquing at the same time.
