Well... I think I've come to the end of the road with this one... I don't have the welding chops yet to get this to work.... tried it on the other arm and got the same result....
Thought I'd have a better chance as there was a decent recess where the bolt snapped off
Got a good strong weld on there which actually forced me to use a longer spanner to try and turn it...
but again... no good.... tried 5 times with the same outcome....
I'm having real trouble with cobalt drill bits as they are literally not even scratching the surface... had to use a carbide milling bit to be able to remove any material
then tried East outs, 200mm long cobalt bits and nothing's touching it.....
So for now... I'm parking it.....leave the arms on the bench until I come up with a solution before I lose the will to live !
so next I think I'll paint the beam black, clean up the Diff and the Anti roll bar... then think about sorting the bodywork...
actually
@Andyboy the decision has been made for me....because of my countless attempts of grinding off failed welding attempts, I've now taken off too much material so the bracket doesn't sit flush anymore..
... so I'm either welding it on or I'm going to have to get another arm....
taken too much off with the Grinder.... b*gger....
