I HATE IT, I HATE IT, I HATE IT, I HATE IT, I HATE IT, I HATE IT, ECT....AD INFINITUM............I have gotten IN MORE TROUBLE AND CREATED MORE AND WORSE PROBLEMS USING EASY OUT THAN I care to tell you. Let's say you have a big bolt that snaps off. Now you're looking at the better half of a bolt stuck in something, let's say an engine block. I KNOW WHAT I'LL DO!!!!!!!!!!!!!!!!!!!!!!!!!!!! I'LL USE EASY OUT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! So you drill a hole in the center of the bolt, and screw in an easy out. You attach the lever to the end of the EASY OUT shaft and begin to turn the EASY OUT tool which is now locked onto the shaft of the bolt. Does it begin to back out the broken shaft of the bolt? $#%T NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! At the FIRST OPPORTUNITY it has, it snaps off inside the bolt and now you have to drill out the EASY OUT shaft from inside the shaft of the bolt. And if you thought it was tough drilling a hole through the center of the bolt, IT AIN'T NOTHING COMPARED TO TRYING TO DRILL A HOLE THROUGH THE EASY OUT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
